It would help to know the make, model, and HP of the engine. However, if the avatar shown is similar to your machine, here is a pic of the spring placement on the carb.
If this is the kind you have, you can easily see where the spring ends go. However, where the springs join to make a "V" is a bit obscure. They join to a loop in the hard link which connects the governor to the throttle plate.
Hope this helps.
**WARNING**
Make Sure the throttle moves freely. If the linkage becomes pinched your engine may run away and either become damaged, destroyed, or may even do harm.
