Sony KV-TG21M61 21" TV Logo
Hasitha Attanayaka Posted on Sep 29, 2014
Sony tv power on after power off,and blink red led 4 time
Lito Yara
Level 1:
Habit-Forming:
New Friend:
  • Contributor 32 Answers
  • Posted on Sep 29, 2014
Lito Yara
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
32
Questions
0
Helped
3897
Points
37
Check out the vertical section.
5 Related Answers
Anonymous
  • 168 Answers
  • Posted on Jan 20, 2007
SOURCE: TV not working
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Anonymous
  • 129 Answers
  • Posted on Mar 28, 2008
SOURCE: Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Anonymous
  • 4234 Answers
  • Posted on Oct 01, 2008
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Anonymous
  • 1139 Answers
  • Posted on Nov 23, 2008
SOURCE: KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Anonymous
  • 6784 Answers
  • Posted on Jun 21, 2009
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
2answers
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
9helpful
3answers
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
1helpful
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
