I would start the troubleshooting process by confirming power at the wall outlet. If this checks out, follow power from the wall to the end of the cord. If you still have power at the end of the cord, check the power inlet. If you still have power on the back side of the power inlet, you may be looking at a bad control board. Repair Parts for Precor 5 17 5 17i Ellipticals Consumer SPORTSMITH net
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
SOURCE: the resistance on my Precor elliptical 5.17 will
There is a small motor under the shroud that operates the resistance motor. It is about the size of a roll of half dollars. Have someone use a meter and check that you are getting power to this. When you turn on the machine the motor should move the resistance forward then back. You can hear this everytime you turn it on.
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
try puting in new baterrys
