Scooter runs slow why?
SOURCE: scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
SOURCE: I have a pride scooter that will not run at top
hi, first check the speed throttle by moving it in the upwards direction while the speed control is turned fully on, if there is a response to moving the speed pot in up and down direction , you founf the fault, otherwise the speed control is at fault, if thats proves to be okay then its the controller breaking down , check the brushes on the motor.
regards
GeWiz
SOURCE: I HAVE A CELEBRITY DX SCOOTER,
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
