How do I change the Phillips head driver
SOURCE: The bit in my Dewalt 6.3 Amp Dry Wall Screw gun
The bits are held by a spring snap ring that sometimes takes a lot of force to release.
Spray a little bit of CRC226 into the bit/chuck interface and grab the bit with a set of visegrips and PULL !!!
The CRC226 is available in a blue spray can at Home Depot in the electrical dept and fights rust. A can is about $2.70... make sure to get the 226 as there are other CRC products there.
SOURCE: I bought a DeWALT adjustable
usually you have to grip it with a pair of vise grips and PULL, sometimes the magnetic driver will come out also but all you need to do it push it back in till it clicks.
Testimonial: "Rowdy, many thanks for your working solution. You have no idea how many calls I made to store staff who failed to help me. Your instructions work! "
SOURCE: I bought a DeWALT adjustable depth screw setter.
grip it with a good pair of pliers or vise grips and PULL. it will come out
Testimonial: "Rowdy, many thanks for your quick response. Many store personnel I consulted failed to help. Your solution worked!"
