I think this is the range, but as I've lost my user manual, it may not be! - Thanks
SOURCE: what type of gas?
Only if you fit the correct jets to the burners.They usually come with the oven
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
SOURCE: gas mark nob not having any effect on gas levels
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing the Igniter
heatman101
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
