Question about Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB
Having a hard time getting my tv connected to the internet
    New Friend:
  • 125 Answers
Check your settings and also check for a firmware update for your router.
Posted on Dec 03, 2014
SOURCE:
Tv connects to Internet to use smart TVs function but cannot recall function after switching tv on after it in standby mode,but ok if I re-install smart TVs function.
System control memory IC fault. Check and replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.
May 12, 2016 | Televison & Video
How do I connect my new smart TV to Netflix, it keeps telling me that ther is no internet connection
The TV Needs to be connected to an Internet Connection!
Either Wirelessly, connected to a Hotspot - most likely your WiFi from either your modem or router, depending on how you get online?
Or... Your TV can be hard wired, with a cat cable directly from your Modem/Router to the TV.
If hard wired, double check in the settings page of your TV (Navigate there with your remote) and confirm this.
If wireless, again navigate to settings and scroll to Network Connections, or something similar, (can't be specific since you didn't provide make and model) choose wireless, locate your home network name, enter your Password, and your TV should now connect to Netflix, among other platforms.
Good Luck
Jun 01, 2015 | Computers & Internet
I have problems with my internet
Wow, could you be a little more vague? Hard to help you with such a broad problem.
Computer Internet problems?
TV Internet problems?
ISP Internet problems?
WIFI Internet problems?
Cell Phone Internet problems?
Connectivity Internet problems?
Router Internet problems?
Well I think you get the point. And this is not close to a complete list. Sorry!
Feb 12, 2015 | Computers & Internet
I was told that an external hard drive would not work with my media player (Sony Internet TV) unless it had a power supply. I went out and got one of those, loaded a few movies on it, and tested it out. It...
1- The usb connection on the media player does not supply enough current for fulsized drives.
2-The drive format and file system needs to be something your media player will recognize, most likely FAT32
Oct 05, 2013 | Sony Nszgt1 - Internet Tv & Blu-ray Disc...
Hp w1907 VGA no input signal
its is telling you the truth (99.9999999% of the time)
believe it !
no PC stated
no TV model stated nor clear connections stated.
are you trying to get the PC (the tower means that)?
to run to video concurrent ports at the same time?
so do both fail,
VGA side
and DVI side,
you never said.
hard to help lacking
what TV
what Tower
what connections, and special adapter (HDMI)
the TV has DVI??
sorry, cant see what you have there. at all.
Feb 01, 2018 | HP w1907 LCD Monitor
I have a pc that the screen stoped working. so I have it connected to my phillips tv via HDMI, and it was working good like that. but know every time I shutdown and restart I get "prepare boot to...
Your tv will only work when it is hard wired to the computer output. With no connection, of course, it is not going to work!!!!!!!!!!!!!!!!!!!!!!!
Aug 25, 2017 | Computers & Internet
I purchased a Sony Bravia EX710 (46 inch) TV yesterday. It works fine except I cannot get the wireless adaptor (which is plugged into the USB drive) to connect to the internet. I have entered the access...
I believe you have entered Access PIN for the network but check at the same time if you have entered user name password for your internet service provider.
Reply if you are able to resolve the issue
Nov 18, 2010 | Sony Televison & Video
How to hook up tv with internet hard wired to existing router with wireless connection to computer ip address on computer will not connect tv to internet help
Assuming that you have an "IP" TV, run an Ethernet cable from the TV to one of the LAN ports on the router.
Run another Ethernet cable from your computer to one of the other LAN ports on the router.
Both the TV and the computer should now have Internet access.
Do you have a third computer that has a "wireless" connection to the router?
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Logo
212 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
