Saniflo & Saniplus& Macerator Pump  Logo
A
Anonymous Posted on Sep 28, 2014
<!-- from fixya rte -->Wire a saniplus capacitor - Saniflo & Saniplus& Macerator Pump
nivek1
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on Jun 02, 2015
nivek1
Contributor
Level 1:
New Friend:
Answers
37
Questions
0
Helped
40928
Points
66
There are two wires, doesn`t matter which way round you connect tham
2answers
Replace the capacitor on my saniplus
This post about the same problem has proved helpful. Hope it works for you Google Groups
I have a saniplus. hums constantly, no longer spins when flush toilet/run taps etc. Water just sits there and slowly empties overnight - gravity?
Could be an obstruction in the blade, impeller or the discharge line. Also the starting capacitor may have gone bad and is not keeping up with the head pressure, it may need to be replaced. But i would suggest inspectin the unit first for any obstructions.
2helpful
2answers
Bath or shower does not empty,the saniplus hums then stops.but after 30 mins or so suddenly starts working.
Is your Saniplus humming or motor spinning slow or not at all?
It is likely the internal motor control capacitor - It is the most common replacement part for these units and a fairly simple DIY although you will need rubber gloves and bleach.
I have posted repair instructions for the Saniplus here:
Saniplus Repair Instructions
2helpful
Saniflow wont pump
If your Saniplus macerator won't pump and the motor is humming or spinning slowly it is 95% likely that the internal motor capacitor has failed - most common problem with these units
I have posted repair instructions here:
Saniplus repair instructions
1helpful
I got a saniflo plus but motor runs but pump is not pumping?
The internal motor capacitor has failed - most common problem with these units
It is a PDF
Think my young son put somthing down the toilet filled up with watre wont flush but hums intermitently
Definitely there is an obstruction on the blade or impeller inside the pump casing. Pry open the lid using a flat head screwdriver and remove the motor with pressure chamber out of the pump csing as one piece. Once the motor is out inspect the blade (on top of motor) and the impeller which is at the bottom of the motor. Also the starting capacitor may have seized up. If the capacitor goes bad it tend to hum and not pump any waste out.
3helpful
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
I have a saniplus in a bathroom with a sink & shower. It isn't used often. The water backs up in the shower. The toilet won't flush, only hums. Any suggestions?
If the pump is humming and backing up then there is a blockage on the drain pipe, blades or the impeller. Also the capacitor may have gone bad and it will need to be replaced. The capacitor drives the blade and impeller, if it goes bad then it would just hum and not pump out the waste.
4helpful
3answers
It just humms nothing clogged on blades, whats up?
Typically the pump will hum is something is stuck on the blade, impeller or if there is a clog on the drain pipe that is not allowing the waste to be pumped out. The capacitor/condenser drives the blade and impeller, if the capacitor has gone bad it will make the unit hum and not pump the waste out. If there are no obstructions then most likely the capacitor will need to be replaced.
3answers
Pump makes humming noise, but does not flush.
hi sounds to me that it is blocked these pumps are for waste only not paper etc
Top Saniflo Home Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
