Question about Psi Blue Max 2200 High Pressure Gas Power Washer
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine started perfectly; how ever when I squeezed the wand trigger, the engine instantley died. I let the engine warm up and slowley pushed the choke in. I let it warm up for plenty of time; but everry time I squeezed the trigger it instantly quit- it even backfired once before dying. I changed the gas with new gas--after pouring the old out and putting new in. I checked all connections and had plenty of water of proper pressure. ANY IDEAS?
  • 5,692 Answers
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Posted on Jul 04, 2009
    Problem Solver:
I have a Honda 2600psi 2.3gpm pressure washer, the motor runs fine, the pressure is fine for about 5-10 seconds then it feels like the pressure drops and the hose and the water coming out of the gun is speeding up and slowing down. Any suggestions prices on parts would really help tks..
Posted on May 21, 2010
  • 174 Answers
It could be the nozzle or something else is plugged. It is overloading the motor too much. Try squirting it with the engine not running. A good amount of water should come out at low pressure.
SOURCE:
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My Troy Built 2500psi washer will not pump cleaning solution.
Next problem will be the spray head itself. It needs to be cleaned with a small wire from time to time.
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
Jul 01, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Have a troy built pressure washer and the gas is leaking out help
the float is stuck you can either take it apart and clean it or you might get by by just tapping lightly on the fuel bowl on the bottom of the carburator to unstick the float
Jun 20, 2009 | Garden
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
1,038 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
