100G X 0.01G
SOURCE: when i turn on my digiweigh dw 100ax scales F--H
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
SOURCE: Looking for a manual on Kilotech Scales KLB-1201R
This manual is for a KHA-1201R but it might help go to web site and download manual.
www.kilotech.com/index.php?id=397
SOURCE: HOW DO YOU CALIBRATE THE SCALES ON A ROBINAR 34800...
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 (old typ machine 8787 without F1 botton on key pad) & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
Hope this will solve you.
