Computers & Internet Logo
A
Anonymous Posted on Sep 27, 2014
How to install replacement cartridge 1423 for shower
Mohit Tiwari
Level 1:
  • Contributor 35 Answers
  • Posted on Oct 28, 2014
Mohit Tiwari
Contributor
Level 1:
Answers
35
Questions
0
Helped
7129
Points
78
There should be instructions on the printer itself
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 • Home
1helpful
I have a Mira sport shower it works but dose not get hot is it the thermastate that's gone I have had it for about 12 years
The thermostatic cartridge is the part of the shower valve which control's the temperature of the water, therefore if there is a problem with the water temperature, the absolute probability points towards the thermostatic cartridge being at fault.
I would suggest you extract the thermostatic cartridge, remove any bits blocking water flow into the cartridge and then soak it in limescale remover. Put silicone grease on the O'rings. Install it again. If that doesn't work, the element within the cartridge could be faulty, so you could try replacing the element. If that doesn't work you will have to either replace the entire shower valve or replace the cartridge.
All of what I've said is based on the assumption that you are receiving hot water to your shower valve.
I've been working with thermostatic cartridge for many years and can tell you with confidence the above information likely applies to yourself. Shower Thermostatic Cartridge Spares
Nov 22, 2015 • Home
1helpful
Installed new Danze shower valve the water is on but will not come out why?
shut off your water and pull the cartridge out off unit...make sure you have no trash in cartridge...turn water on without cartridge in but only part way to see if you have water flow to value...then make sure no damage to cartridge or some of these have plugs that need removed on install of cartridge....you may need to remove test plug that is in there ....try this...good luck
7helpful
2answers
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
I hook up everything ,but i only gey hot running
Have you tried removing cartridge, rotating cartridge 180 degrees then re-install?
2answers
When I turn my MOEN Shower faucet to the HOT position hardley any water comes out.and it is just luke warm.
check your cartridge,and i believe your mod # 3175 has a balancing spool #1423, i think if i remember it is to the right of the cartridge,a large screw driver will get it out.
2helpful
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Low water flow in Shower
Definitely try reversing the cartridge.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Replaced moen 2225 cartridge leaks when valve is turned on
Make sure that you did not pinch an O ring seal when you were installing the cartridge. If so replace O ring. when installing new cartridge try putting a little Vaseline on all the O rings. It will seal better. It is rare but you could have purchased a defective cartridge. Never buy a cartridge if the package was opened because maybe someone just needed the O ring that is making your faucet leak :-)
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
