The blades are very carefully made so that they slightly overlap. This is why on some machines when you turn one way there will be a strip as described. If you ground the ends shorter, they will not overlap, and this is your problem. You should only sharpen the lower cutting side [NOT THE END] of the blade. Make sure that they are evenly ground back, not more near the outside as this will result in a curved cut with low centres and slight ridges in the middle of the blade paths. Also important to accurately balance them. Place nail in vise and put blade so the exact centre of the hole is on the nail, splined blades can be difficult. Maybe necessary to get ring of tube to fit inside spline. Grind off low end until they hang level.
SOURCE: 48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
SOURCE: Mower leaves a uncut srip of grass through the
The blades need inspected and sharpened,one could have a bent tip or just dull,if youve had someone else pull them off and reinsall them already check to make sure one of them isnt installed backwards,dont laugh,Ive seen it happen.
SOURCE: leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
SOURCE: deck will not shed the grass
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
SOURCE: how do i remove the cutting blades to sharpen them
you could take the mower deck off and do it that way or you could jack the tractor up. i recomend that you use a 1/2 inpact gun or a 1/2 breaker bar
