Does not reset itself
SOURCE: Smart set alarm clock - resetting instruction
First, make sure the time is set correctly – Eastern Standard Time (EST) is the default
Press the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished
Here is a link to the manual:
http://www.emersonelectronics.ca/emerson/en/product/view/17796
-Tha Mp3 Doctor
SOURCE: Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
SOURCE: emerson research smart set cks3528
Sorry it took so long to give you a answer to your problem. This is a factory error code . The best people to tell you what the problem is and how to repair it are the Emerson Service people. They will have all the service information to help you. You can call Emerson customer support at this telephone number 1-800-909-1240. between the hours of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day.
SOURCE: emerson smart set clocks
Sorry it took so long to give you a answer to your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day! Dear Emerson SmartSet® Clock/Clock Radio Owner: Your Emerson SmartSet® Clock or Clock Radio includes Emerson?s patentedAuto Time Setting System that automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and alarm settings for up to 5 years, or even longer. As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/ Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April and ends on the last Sunday in October. The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in March and end on the first Sunday in November. Of course this is a situation that is beyond the control of Emerson, or any other company that produces devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA?s, and many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to make adjustments to the automatic DST software to agree with the new DST timing for 2007. Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows: 1.) On the second Sunday in March you would have to set your clock to the next lower number time zone. For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone 1 to move it ahead by one hour. 2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set your clock back to Zone 02. 3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone. 4.) On the first Sunday in November you would again set your clock back to your correct time zone. Instructions for changing the Time Zone setting are found in the Owner?s Manual. We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
SOURCE: I have an Emerson smart clock radio and cannot set the alarm
Sorry it took so long to give you a reply to your problem. [http://www.emersonradio.com/owners/SmartSet%20Series/] Copy this web link and paste it into the address bar of your web browser. The link will take you to the Emerson customer support web page that has pdf copies of the owners manuals for all the Smart Set Clock/Radio's. You will need to have a pdf reader and writer to read and make a copy of the owners manual. Find the make and model number of Your Clock/Radio and open the manual. You will find all the instructions for setting the alarm. If you are still having problems with setting the alarm. Call Emerson Customer Support at this telephone number 1-800-909-1240 between the hours of 8am-4:30pm CT. Tell them the make and model number of you Clock/Radio and ask them for assistance. I hope this information will help you with your problem. Thank you for using FixYa and have a nice day!
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
