Radio Communications Logo
A
Anonymous Posted on Sep 27, 2014
Super2000 i have no audio output on ssb am fm ok ?
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Dec 26, 2014
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
206108
Points
1873
Problem with the ssb filter if am & fm are ok
3 Related Answers
Anonymous
  • 17 Answers
  • Posted on Feb 02, 2009
SOURCE: pro 640e
How are you testing the audio out?
Are you using another radio?
If so, are you REALLY sure the other radio is ok?
If the other radio is ok, how do you know the mic is ok? have you tested it with another radio?
If the mic is ok, id have a look at the mic socket to check that all the pins are still there. Then open the radio up and check the socket is still connected to the main board.
Let me know how you get on..
M3ODQ
anymhz
AnyMHz.com
  • 500 Answers
  • Posted on Jan 06, 2011
SOURCE: Magnum 257HP ,Poor TX audio , tried several mics
That mod that magnum does really ups the sensitivity. so much thats is too much. If that model has a switch for the compressor turn it off. It will help 100% and make it sound decent not twangy and over modulated. Just the design of these newer exports are not like the old ones.
Anonymous
  • 6771 Answers
  • Posted on Mar 24, 2012
SOURCE: NO variable power on FM,or SSB, but variable works ok on AM
Look for open resistors near by, if the 2SC1969 shorted it has taken out one or two parts, also check for open foils on the printed circuit, beyond this a circuit diagram is needed.
Mic only works FM but not SSB
I suggest check the microphone connector and cable first. Are they OK ?
How do i adjust the sideband
Instructions
Connect one end of your coaxial cable to the output port on your SSB Transmitter. Connect the other end of the cable to the coaxial input port on your RF demodulator.
Connect one end of your 1/4 inch audio cable to the audio output port on your RF modulator. Connect the other end of the audio cable to the audio input jack on your amplifier.
Turn on your SSB transmitter, RF modulator and amplifier. Adjust your SSB transmitter modulation by adjusting the knob on your RF
Problem with Superstar 3900 CB Radio
did you found the problem,mine has the sam problems...reception not very loud on ssb,am fm very good...
Magnum 257HP ,Poor TX audio , tried several mics ,SSB ALC , Bias no effect . Did not align TX lower stages . AM , FM are perfect , all RF power outputs perfect , looks good on scope with generator but...
Rci 2980 no modauliton on am/lsb/usb/fm.but good recived. and good output.on am.
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
1helpful
3answers
Magnum 257 it will not transmit on lsb or usb it will on am and f
With SSB you have to put audio on the carrier you cant just key the microphone and expect it to output a signal unless you talk into the microphone at the same time this is how SSB works.
So if you talk and the meter starts to move then its ok, if you talk or whistle and nothing moves then the circuit on the SSB side of the unit is faulty.
Excalibur works fine one day than not the next...
sounds like some loose solder joints. check power output with external meter to see if output is ok . i think youprobably have 2sc1969 finals init unles someone has changed them theyshould put about 25 watts if tuned correctly. also check the antenna a and antenna b switch to see if something has shorted across it inside cabinet.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
