It sounds like your motor is going bad. When an electric motor has some age, the motor brushes will wear out and fail to make contact inside the motor. The missing sound you are describing is probably a burnt spot on the armature where the brushes are not transferring electricity. If the unit is an expensive unit, you may be able to order replacement brushes for the motor, or even better.... a replacement motor
