SOURCE: innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
SOURCE: need help with HO 800sentry dynamic wireless headphone?
You need to plug in the RCA plugs (red and white) to your cable receiver box and NOT the TV outlet.
If you have satelite box, it's the same thing. It has two sets of audio-out and one of them goes to your TV and the other set may be free.
If not, goto Radio Shack and get a SPLITTER so you can plug in the headphone set.
However, these headphones... I have one, may not be all that good quality and reliable.
SOURCE: station to get signal from FM transmitter
I put the transmitter closer to the antenna and it periodically worked. So, I don't there is a specific station.
SOURCE: fm wireless headphone batteries not charging
you need to replcae the charging pin of your head phone, it is having loose connection............
SOURCE: I need help installing A Merkury Innovations
hello, i have a philips wireless head set and this how i set mine up, i take it you've got the sensor with long black wire attach to it this plugs into your earphone socket on your tv set then plug the power adaptor the sensor switch on make sure the sensor pointing towards you and put the batterys into the earphones and switch earphones on you should have sound get back to if you have trouble thanks
regards
shaun
