Lg door on door 28 cub foot refrigerator
The sediment is the result of the minerals in your tap water precipitating to the bottom of the glass after the drink has sat for awhile. The minerals in the ice cause you ice to be cloudy and not clear. The only way to reduce or eliminate the sediment is to filter the water going to your ice maker and water dispenser.
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
SOURCE: fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
SOURCE: lg, french door, bottom freezer ice maker doesn't
It is possible that your ice maker has gone out. Can you tellme how old yiur refrigerator is? Normally , they can go out after abouit 18 monthw depending on different instances.
We will be happy to help get you going agin. If you would like for us to continue to assist you, you can contact us at :
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We are at your service and look forward to working with you.
SOURCE: LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
