SOURCE: HP PSC 2210 All-In-One InkJet
I undertand that you are receiving a blank page when printing from computer.
Please follow the below given instructions to get the issue resolved which is caused due to DEP feature of Operating sytem.
Disable the Data Execution Prevention in Windows XP and check by following the below steps:
1. Click on Start
2.Control Panel->System->Advanced->Performance->Settings->Data Execution Prevention
It needs to be set to "Turn on for essential windows programs only", which is the default.
If you set it to "Turn on for all programs except those I specify", then the all-in-one driver stops working and you get blank pages.
1) Right-click on My Computer, and select Properties.
2) Click on the Advanced tab.
3) Under Performance, click Settings.
4) Click the Data Execution Prevention tab.
5) Select the Turn on DEP for all programs and services except those I select: option.
6) Click Add....
7) Browse to C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng05.exe
Or
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng07.exe
and click Open.
8) Click Apply.
9) Click OK, and OK again.
Then restart the computer so as the chages to be effective
SOURCE: MY test page always prints
I belive that after replacing the INk cartridges, you are
experiancing this problem. The Alignment test sheet always prints
everytime you turn on the printer, if u haven't completed the Alignment
process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
SOURCE: MY inkjet printer getting print double letters double printing on one page
need to clean carridge block rod
black smega found there
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: HP Photosmart 7760 InkJet Driver download error
Download and run the patch below from hp then restart your computer and run the install for the printer again.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-24444-2&lc=en&dlc=en&cc=us&os=228&product=305375&lang=en
