Have tried all alternatives but none will work.Do i have to buy another cable ?.
Make sure you are connecting to the TV's audio-OUT jacks, not the audio-IN jacks. Also, check the TV options menu. Some TVs have a choice of internal or external speakers and you have to select one or the other; obviously, you would select "external".
On the soundbar make sure you have selected the correct input jack for the audio cable.
SOURCE: how do you use the s-video cable
You may need to download the correct codecs for your laptop and software if need be . Does your note book have hdmi port or dviport? If so use you will not need to do all this, go to wal mart and pick up either cable and plug in . Thats it. Unless you are computer savvy, i would try an alternative means first, E.G. HDMI, dvi to hdmi
SOURCE: i have a sanyo tv and it dvds
you may need to use something other than the "video" screen. Try channel 3 or 4 . Or search for another input
SOURCE: is it possible to connect
yes it is possible there is one HDMI input on the back of the television
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
