Samsung HLR5667W 56" Rear Projection HDTV Logo
georgia thompson Posted on Sep 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Would a Samsung hd hlr5667w be a rear projection tv? just not sure
gemagm
Level 3:
Master:
  • Samsung Master 689 Answers
  • Posted on Jan 31, 2015
gemagm
Samsung Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119689
Points
1147
Yes, this is considered a rear projection TV.
5 Related Answers
Anonymous
  • Posted on Dec 05, 2008
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
how do i converge
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on May 15, 2009
SOURCE: Samsung 47" HD Projection TV with color distortion
COLOR CONVERGENCE IN THE MENU
Anonymous
  • 206 Answers
  • Posted on Aug 04, 2009
SOURCE: samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Anonymous
  • 62 Answers
  • Posted on Sep 25, 2009
SOURCE: Samsung rear projection TV audio no video
There is a problem on the deflection board (BP94-00501B). I have tried replacing the flyback, both convergence IC's and the horizontal output transistor without any luck. I finally bought the whole board from encompass parts for ~$120. Hope this helps.
Anonymous
  • Posted on Dec 21, 2009
SOURCE: HLR5667w Samsung.. Screen showing green stripes on
mi reproductor de mp3 Yp-u3 enciende y de apaga rapido y me aparece en la pantalla resource data y the players is off eso sucede desde que le di formato en el mismo equipo por favor ayudeme.
garcias
Samsung HLR5667W 56-Inch DLP HD TV not working
A black and white picture usually indicates the color wheel has failed or the DMD board has failed. Call 1-800-samsung to find neaREST SERVICE CENTER.
Samsung hlr5667w TV made a popping noise then the picture started
Most likely. You should remove the lamp door, pull out the lamp, and inspect it. Look into the center of the lamp, does it look dark or swollen? Does it look chalky on only one side? Did it burst? If so, you definitely need a new lamp. I hope this helps.
2answers
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
HLR5667w Samsung.. Screen showing green stripes on SD cable channels. Works normally on HD channels. Not the Cable.. other tv's work fine. Go from one SD channnel to the other and image from previous...
garcias
TV won't come on ...
These newer sets are haveing power supply problems the capasitors all go bad. If the tv is out of warrnty it will cost a lot to repair.
TV won't turn on
you need a new lamp. the error is for dead lamp
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
