OK, the wiring that you should have in your RV is as follows: Red White Blue Yellow Green Gray.
This Thermostat will not work on this Air conditioner because the tstat you are installing is a 24V thermostat. The connections are as follows G = Fan, W = White, Y = Cooling, RC = 24V Cool, RH = 24V. The only thing that I can think to do is hook it up like so.
On the G Terminal, Hook up the Green wire from the wall. On W, hook up the White wire, Y, hook up the yellow wire. RC = run a jumper from the RH terminal, RH = hook up the red wire. If this doesn't work then you will have to go back with the coleman thermostat.
