Question about Electrical Supplies
Cummins generator starts but no power
Generator has been sitting and starts but doesn't generate power
    Habit-Forming:
    Scholar:
  • Electrical S... Expert
  • 80 Answers
Cummins generator set will occasionally encounter generator failure in the process of use that Cummins generator set is not generating electricity. What is the cause of it? And what to do about it? In fact, there are a lot of reasons that Cummins generator set is not generating electricity.
1. Wrong connection of generator set. Processing: check and correct by wiring diagram.
2. Generator speed is too low. Processing: measuring speed and keeping it at rated value.
3. The connection between the stator winding and the generator distribution equipment has sludge or oxide, the connection screw is loose, the connection wire is broken, and the stator winding is broken. Handling: use a multimeter or lamp test method to find out where the wire is broken. Check the connection and contact of each connection screw.
4. Excitation circuit broken or bad contact. Processing: use multimeter to identify broken wire and reweld the broken wire to bind insulation.
5. Rectifying tube (including rectifier diode, thyristor) is damaged. Treatment: replace damaged parts.
6. Brush contact with slip ring bad or brush pressure is not enough. Treatment: clean the surface of the slider ring, polish the brush, make it match with the surface of the slider ring, increase the brush pressure.
7. Brush grip rusts, brush can not slide up and down. Treatment: wipe the inner surface with a cloth brush, if damaged, should be replaced.
8. Cummins generator exciter brush position is incorrect, brush damage or spring pressure is not enough. Handling: adjust the brush to the correct position, replace the brush, adjust the spring pressure.
https://www.dieselgeneratortech.com/cummins
cummins generator starts but no power - cummins diesel generators-4g5wdwgei0pdvlmlmfm22efu-3-0.jpg
Posted on Oct 26, 2018
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
WHAT MODEL WHAT SPEC? DETAILS ??????????
Posted on Mar 01, 2015
SOURCE:
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
Posted on Jan 26, 2009
SOURCE: Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
Posted on Jul 29, 2009
protek480
  • 1730 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 01, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
Have an ex1000 generator it has for gets fuel just won't kick over
Dear, your meaning is 1000KW generator? It fails to start?
If it is, maybe you can get some help from this article. Why Diesel Generator Fail to Start
If you want to inquire diesel generator/silent generator set, kindly visit this website. Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
Any questions, kindly contact me.
Sep 20, 2017 | Electrical Supplies
Check engine ecu light keeps comming on 2006 volvo
Get OBD (on board diagnostic) from auto zone and plug it into car to read error codes.
Oct 08, 2014 | Volvo Cars & Trucks
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
My 3000 watt honda generator doesn't seem to put out the proper power
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf
I would check spark arrester and clean it and the muffler first.lt could be the inverter unit. If you have a meter determine the output voltage, and freq. You would need a scope to look at waveform the repair should be lest to a repair center. suggest you call Honda for more guidance.
You could spend a lot of money on maybe parts./
Nov 30, 2017 | Honda 3000 Watt Portable Generator
How to manually reset power command hmi211 for cummins generator for low coolant level
Generator show establishing communication with control
And write some below (scrn pno3266796 v 4.50)
I am try to start generator but generator not start.
What Problems.
Apr 01, 2013 | Motorcycles
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
There is problem with my cummins generator the is
check fuel filter it may be only getting enough fuel to run up to so many rpm
Feb 10, 2010 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
Electrical Supplies Logo
128 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
