My Yaesu Ft-857 transmits ok on 2 meter. But the receive only work sometime? As I was stating. My 857d transmits on 2m with no problem. But the receive only seem to work some time with repeaters and simplex as well. I have a HAM friend less then 3.7 miles from me and he can not open my squelch with a repeater nor can I hear him on simplex. Yet with a group called SKYWARNING, I could hear almost everyone on the repeater?
SOURCE: Yeasu FT 897D
I suspect that the extended transmit will really allow you TX on 2 Meter from 136-174 or thereabouts even with modifications.
At any rate, Air Bands are amplitude modulated, have you tried switching mode to "AM" when operating 116-136MHz??
Would you post back please on how the modification (extended transmit) was done;
software programming of the EEPROM or jumpers (JP1001-1009).
Good luck and kind regards.
SOURCE: ic w32a
Thanks for letting me post a question.
After taking it apart again I found a pin on the lower board socket that got bent over on reassembly........
SOURCE: Some bands OK some not. No transmit, no readout on some.
its the problem of the frequency range its getting blocked at particular location.these can be solved by two options
1)first try changing the location of the unit from one corner to another corner.that should help to catch the frequency again if its getting blocked at particular location.this happens many times.but if changing the locan does not make any difference.then
2) get checked that the antenna of the unit is not catching the required frequency for the unit.so change the antenna also connect this external antenna as mentioned 50 ω (it comes wioth SMA Connector) that helps in catchinf the frequency.
you will get this at radio shack website. this will help.
also in the unit there is a component which controls the frequency called microprocessor if that goes weak the unit slowly slowly stops receving the accurate signals and only the noise comes.so the micro processor in located internally in the left side.its a green and black colour mini chip circuit board.many times opening the unit and removing and cleaning the microprocessor and refitting it solves the problem but this is 50 --- 50 chance.
this all has to be checked what mentioned.
thank you for using fixya.
SOURCE: Bands covered by Furuno FS-1502
It doesn't appear to cover the ham bands, only maritime. This radio is also not type approved for operation on ham bands either.
You can find the freq. range in the manual at the link below:
http://www.furunousa.com/Furuno/Doc/0/AHHEA1GA2ITKN04R23GBMOTKF1/FS1502%20Operator%5C%27s%20Manual%20Vu.pdf
Nice Radio though.
SOURCE: Yaesu Ft-60R with Kenwood TK-3107
ok guys!! i have gold for your prob huhuh
go to this website and u can get anything about all model TK
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
