Was the first repair of good enough quality or were recycled products used?
SOURCE: Black screen
If ya can get the parts easily then it's NOT too hard to replace the "Back light" there isn't too much inside these monitors, generally there are 3 main parts the LCD and it's electronics, a Video interface for Monitor - PC,and the Power Supply Unit, (PSU). I have found that a VERY high percentage of problems with Monitors like this are in the PSU, and generally it is faulty, Electrolytic Capacitors... Personally unless it was an "Easy Fix" I would opt for another unit with a 3 year warrenty...
SOURCE: Nintendo DS Lite Console - Repairable or Not?
um well if this is happenig i sugest that you call the number on the back of the ds and ask them what the problem is its about 45$ to send it in and get it repaired but no leaving it in the car would not do this because i have dropped it in my pool once (lol) and nothing happened to it i just let it dry so as long as it isnt still moist then it will work also it may be your battery try taking it out and pluging in to the charger and using it without the battery. and you said that it does it half way through the game try another game.
SOURCE: Q Box problem
wow, it just goes to show you that even big name brands have poor qc or qa on their products.
SOURCE: denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
SOURCE: We have a Westinghouse WSE6100SA
This could also be an issue with simply too much food in the fridge blocking some of the air channels or that there are containers in there which are uncovered which contribute to high humidity in the box.The unit may also be left open too much.
Before blaming the manufacturer/servicer...let's look at the usage cycle. This ice is coming from somewhere! Do a full defrost of the unit. Keep it closed after loading in food. What is the temperature in the box? 40F in the fridge and 0 F in the freezer is about right. Use an outdoor thermometer and check after an hour of closed door.
