Question about Korg KP3 Kaos Pad Dynamic Effects Sampler
I bought a KP3 second hand. It seems that the Y-axis is not working. When I touch the touchpad onmy the two highest squares are lit and there is no change of sound? It seems that sampling isn'
I bought a KP3 second hand. It seems that the Y-axis is not working. When I touch the touchpad onmy the two highest squares are lit and there is no change of sound? It seems that sampling isn' t working either? Are such problems known and is it fixable?
I have a Korg KP3 with a faulty touch screen. How can I get this fixed?
Take it appart rub it with pure alcohol an put the touchpad together again
Nov 23, 2014 | Dynamic Korg Kp3 Kaoss Pad Dynamic Dj...
Touch pad not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 04, 2012 | Computers & Internet
How do i unlock the pointer pad on my easynote
It sounds like your touchpad has been toggled to off. You need to toggle it on.
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
May 16, 2012 | Computers & Internet
Hp zv5000 touchpad problem
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 10, 2012 | Computers & Internet
Touch paid not working
Maybe you have the touchpad turned off. Some models have a switch that is located at the top of the touchpad in the middle that toggles the touch pad on or off.
Some model you have to tap twice in the upper left hand corner of the touchpad to turn it on or off.
Some model you have to hit keystrokes that toggle it on or off. You might have to Press and Hold the ALT key or the FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The key that toggles the touch pad will have a finger pointing at a square that represents the touchpad.
Apr 30, 2012 | Computers & Internet
What is touch pad onmy acer aspire 5532, and how can I turn it on/ use it?
I just so happen to have the same computer, look at the top where the on and off switch is at, on the left side is the on and off button for the touch pad. You should see a orange light on when the touch pad is disabled. It's the button with a drawing of a hand on a square. If the orange light is off then the touch pad is enabled, now you have a different problem.
Now go to Device Manger (via start,control panel, Systems & Security -- should see Device Manager in blue), go to Mice & other pointing device, right click on the Alps info, then click on update device driver. If Windows doesn't automatically update, then you have to go to Acer's webpage, then support, then drivers and downloads, fill in the info on your computer to be directed to the proper driver, then download the driver file for Alps mouse/touchpad. This should help (I hope), good luck.
Sep 17, 2011 | Computers & Internet
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
May 02, 2010 | Acer Aspire 3000 Notebook
Emachine E725 touchpad does not work
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
What has happned if i can't use my touchpad?
press fn key and the square and hand on it and it will unlock the touch pad if this doesn't work then let me know
Nov 07, 2009 | Office Equipment & Supplies
Korg KP3 Kaos Pad Dynamic Effects Sampler Logo
566 people viewed this question
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
