2001 Chevy Malibu Front & Rear Wheel Bearing & Hub Assembly Set of 4 Logo
Michael Renteria Posted on Sep 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Po502 chevy malibu
Need flow chart for dtc po502
Kardoc
Level 3:
Top Expert:
  • 1A Auto Parts Master 7,503 Answers
  • Posted on Mar 17, 2019
Kardoc
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2759954
Points
58323
2001 Chevy tahoe is there a free dtc chart?
There are plenty of online website where you can look up codes. What codes are you getting I may be able to help?
1helpful
2answers
What is wrong and can it be done cheap and by me?
Check out the videos on the power steering. See if there is a local college near you that does automotive classes and ask if they can fix your car for practice?
https://www.google.com/search?q=2011+chevy+Malibu+and+the+power+steering+is+going+out+along+with+the+ESC
Error code PO410 came up on my 2005 chevy trailblazer what do i need to do to fix this please
Do you know what a code diagnostic flow chart is ? You need to look the code up in a service info. repair manual an do the diagnostic's associated with that code. Test circuit wiring , view scan data etc.....
DTC P0410 Secondary Air Injection (AIR) System
Video's on youtube showing how to diagnose this .
1helpful
2answers
I have a 2006 GMC 1/2 ton pickup with 5.3 V8. Engine light came on and upon checking, it has a P0442 and P0442 P code. Any suggestions on this? Also how do I erase the engine light.
You erase the engine light by fixing the problem . With every DTC - diagnostic trouble code there are diagnostic flow chart's , steps to find the problem .
DTC P0442 : Evaporative Emission (EVAP) System Small Leak Detected
How to Diagnose P0442 Small Evap Leak 04 Chevy Avalanche
2002 chevy malibu...can i get a remote starter to by pass the anti theft system
What makes you think this is a anti-theft system problem ? Is the security light lit on the insturment cluster ? When you turn the key to start does the starter spin the engine ? Crank no start ! Or when you turn the key to the start position the starter does nothing . No crank no start . A aftermarket remote start won't by pass anti-theft system . Your best bet would be to take to a qualified repair shop and have it checked for DTC'S - diagnostic trouble codes . Before you let someone start hacking up wiring circuits .
DTC B2947
DTC B2948
DTC B2957
DTC B2958
DTC B2960
DTC B3031
DTC B3033
DTC P1626
DTC P1630
DTC P1631
DTC P1632
Do you know what DTC'S are , these would point to an area of trouble an to a fix .
2007 chevy colorado DTC code P2610
BEFORE ANY THING. CK YOUR CABLES TO THE PCM. TAKE THEM OUT AND PUT THEM BACK IN. ALSO, MAKE SURE MASS AIR FLOW CONNECTIONS ARE TIGHT.
1helpful
99 chevy malibu no dtc code p1665
where can I find the P1665 Evap vent solenoid control circuit on my 99 Malibu?
5helpful
Dtc code p0121 and p2135 2007 chevy malibu
both codes refer to the throttle position sensor, the sensor is at the throttle plate, on the side of the throttle body. to test remove the connector to sensor, use a ohms meter to test. put 1 lead to top connection and the other to the bottom one. move throttle and the needles on the ohms meter should move very even, move throttle slow to get a good reading, needle should move without no hesitation, if the test is bad replace tps sensor. if the sensor gets to bad, it can have an effect on transmission shifting. after fixing sensor have the light turned of with an obd2 scanner.
What is the code P0816 on a 2006 Chevy Malibu? What would be an estimate on the part to buy it?
P0816, Downshift Switch Circuit, PCM, TCM, DTC P0816 (2.2L and 3.5L) for the 4T45-E transmission or DTC P0816 for the 4T65-E transaxle. ...
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Jesse Walters
Jesse Walters
john h
 Mikey
Mikey
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
