The hard drive would not show up until you initialize it in the control panel. With everything off the motherboard you should get some post beep. Put the ram back and try again, the next thing to install is the video to see if there is any indication of function. Keep adding things back. If there is no post beep with just the motherboard then you need to test the PSU and if it is OK then CPU or motherboard is bad.
Testimonial: "thanks Brad Is there any way to check the PSU for proper function, please keep in mind , the green light on mother board is lit on , the CPU fan runs prefect and by disconnecting the monitor socket from the MB the Disconnected Cable Signal appeared on the monitor. I'd like to have your kindly recommendations, Hoss"
