Question about Nortel Meridian M7208 Corded Phone
MY m7208 suddenly has no external volume for intercom. It doesn't ring and when I push the volume buttons nothing happens.
2 Suggested Answers
SOURCE:
  • 27 Answers
SOURCE: Nortel M7208 eliminate intercom button
You have to go in to main system programming , It is best to use a M7310 phone if you have one . Press Feature ** 266344 when it ask for a pass word re-enter 266344 . First go to terminals & set and enter the ext you want to program press the show button then press the next button until you get to intercoms . press show then press the change button under the soft key until you get to 1which will be the new number of the icm on the phone . Now you can program a feature on it .
Posted on Apr 01, 2009
My phone will not ring anymore - neither the handset or the base unit. There is no menu button to push. HELP!
You can select the ringer volume to HIGH, MEDIUM, LOW or OFF on the handset and the base unit separately. The factory preset is HIGH. If set to OFF, the unit will not ring for external calls and will ring at the LOW level for intercom calls.
1. Does the phone dial out ?
If yes go to next question. If No check line.
2. Do the displays flash when the call comes in ?
3. Is the volume setting too low.
either way refer to manual attached here Panasonic KX TG5100M Operating Instructions Manual
Mar 11, 2016 | Panasonic KX TG5100M Cordless Phone
Got m7208 phone but can only just hear the caller
There is a caller volume control. In a call, locate the volume buttons and push the upper one. The volume should increase. If this doesn't help, it may be the speaker is blocked, or just plain bad [electronic devices have been known to arrive bad out of the box.
Mar 22, 2012 | NorStar M7208 Corded Phone
Norstar meridian 7208 won't ring.
Does it ring when you move it to a known ringing port? Is it programmed to ring (Terminals & Sets) Appear and Ring? Do you have Automatic Set Relocation turned on so the extension number stays with the phone?
There are a lot of features to check for ringing, including the volume of the set.
Carl
Sep 10, 2011 | NorStar M7208 Corded Phone
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Sep 10, 2010 | Nortel Meridian M7208 Corded Phone
Our office has a combination of Norstar M7310 and Norstar M7208 phones. One of our M7310 phones died today and I wanted to trade it out with a M7310 that was in my office. I followed how to turn off the...
Dial "F * 0" (Feature, star, zero), which is Button Inquiry, and press an intercom button to see the extension number of the telephone. If Set Relocation is set to "Yes", then the extension number & mailbox will follow the phone when it is moved. Move only two phones at a time, and wait until they completely "boot-up" before moving additional phones.
Hope this helps.
Aug 04, 2010 | NorStar M7208 Corded Phone
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
Unable to use conference button
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
Phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
Aug 03, 2008 | AT&T 954 Corded Phone
Nortel Meridian M7208 Corded Phone Logo
59 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
