SOURCE: Canon Powershot A75 problems
Having read on a few sites about loose ribbon wires causing problems and having this same problem. I decide to take the camera apart. Taking all the screws out and fidling with the "wires" connecting the zoom control and the photo type selector and the main circ board. I also cleaned the connector from the picture type selector. Then put it all back together the camera works fine again. NOTES... lots of small screws with varying lengths make sure you know where they come from. Took about 1 hour to do.Put back in the order you take apart or the back will not go back on.. Good luck have just saved myself a fortune
SOURCE: Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
SOURCE: Problems with the battery and the flash on my canon powershot A530
Know this is an old post but... Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mentioned that your batteries weren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
SOURCE: Camera won't power up
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
