My electrolux 2100 vacuum cleaner will not go on, the protection light is light when ever I try to turn it on. I have changed the vacuum bag, filter and checked the cord. I have also made sure the little pressure switch is operable when the bag goes down.
SOURCE: Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
SOURCE: Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
