Vehicle Parts & Accessories Logo
A
Anonymous Posted on Sep 25, 2014
MY 2002 OLDSMOBILE INTRIGUE STALLS FOR NO REASON WHEN I AM GOING DOWN THE ROAD
bikersailor
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 05, 2019
bikersailor
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
3128
Points
22
I would check your crankshaft sensor , also your fuel filter to make sure it is clear
5 Related Answers
Anonymous
  • 365 Answers
  • Posted on Jun 15, 2009
SOURCE: Where is my smog pump located in my 2002
Smog related "error" may be covered under manufacturer warranty...it's a Federal Law 10yrs. on emissions equipment...However, they may still charge the labor to do the repair look for $129-150
Good Luck
REDOIL
Earl Norager
  • 355 Answers
  • Posted on Sep 28, 2009
SOURCE: SERVICE ENGINE SOON LIGHT ON FRO oLDSMOBILE 2002
need to see what code say go to local part house and most do it for free and they will let you know what the code is wright it down the come back with code we can help then
Anonymous
  • 39 Answers
  • Posted on Oct 19, 2009
SOURCE: My 2002 Expedition stalls when I try to put it in drive
vacuume leak? - mass air flow sensor dirty or faulty.
Anonymous
  • 1077 Answers
  • Posted on Oct 25, 2009
SOURCE: 2002 OLDSMOBILE INTRIGUE GX engine light on
There are many emission sensors in the car that will make the engine light come ON. Not to mention the big list of trouble codes for the engine light.
Best way to find out what's going on engine light is to have an auto-parts store hook up a engine code reader and tell you what the code means and the problem. Most auto-part store will do this for free.
Anonymous
  • 672 Answers
  • Posted on Mar 09, 2010
SOURCE: 2000 3.5 oldsmobile intrigue stalls or misfires
You might have an issue with the crank or cam sensors (have these cecked). The crank sensors on these models tend to fail, typical symtoms include; misfires, hard starts, stalling. Check also your coil packs (they are mounted atop the sparkplugs as a set). Hopefully this helps!!
Does the Oldsmobile Intrigue 2002 GX 3.5 V6 have two mufflers
Depends no design, look at both exhaust manifolds, follow them back and down and look to see if the meet somewhere under the vehicle and connect to only one pipe that leaks to muffler and tail pipe.
2002 olds intrigue service manual download
Here you have the manual:
http://justgivemethedamnmanual.com/oldsmobile/2002-oldsmobile-intrigue-owners-manual
Engine stalls for no reason, will only start back up and run with T.W.O. or when feathering pedal.
Sensor/computer problem. Take to autozone and have it hooked up to diagnostic tested. Free service.
Flasher blinks fast and then blew out and so did the headlight in my 2002 oldsmobile intrigue
The problems are probably related in some way. Let's reason this out...If there is an intermittent short in the wiring somewhere it could blow bulbs. If you have poor grounds on the MANY ground wires in the car and in the engine compartment, sudden surges could be taking out fuses and bulbs. If you really want to find the solution(s), you will need a wiring diagram of the complete car. You can get one by going to the auto parts store and requesting a Haynes auto book for a 2002 Oldsmobile Intrigue. In it you may find some hints like I gave you. Try to trace the worst problems first so that you can keep the car on the road (pass inspections)...
1helpful
2answers
2000 3.5 oldsmobile intrigue stalls or misfires after driving for 10 minutes - thowing it in neutral and reving it keeps it going
2helpful
2answers
Car keeps stalling,it is a 2000 olds Intrigue
try fuel filter new plugs plug wires or u may have water in your gas
2helpful
2002 oldsmobile intrigue starts but stalls only once.
You have a bad crankshaft position sensor. When the thermostat opens on warmup, the auxiliary air pump starts up momentarily which causes a quick dip in battery voltage and drops the output from the crankshaft rotation sensor. the computer thinks the engine is not running and shuts down the fuel. If idling, engine will die, if moving sometimes will just hiccup.
Intrigue starting problem 2002
crank shaft position sensor replaced.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
