HKC 7" Touchscreen 8GB Tablet 1GHz Android 4.0 Logo
A
Anonymous Posted on Sep 25, 2014
Need to reset. grandson loged
It will not allow us to sign back in. states to many pattern attempts. attepted google recovery by screen is locked. Wont even allow us to log into the internet
CCervantes
Level 2:
Habit-Forming:
New Friend:
  • Expert 77 Answers
  • Posted on Sep 26, 2014
CCervantes
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
77
Questions
Helped
10624
Points
108
Hard reset, Press the volume up and power button for about 10-15 seconds to reboot. Wipe data/Factory reset.
T47B Tablet how to unlock screen forgot code
Hi Mate,
  • On the unlock screen, enter your unlock pattern
  • After five attempts you'll be asked to wait for 30 seconds. Tap OK
  • If your phone display goes off, tap the power button and unlock your screen
  • Tap Forgot pattern? If you haven't set up a Google account you won't get this option, instead you'll need to reset your tablet
  • Enter the username and password of your Google account, tap Sign in
  • You'll be asked to create a new screen unlock pattern. If you don't want one, tap Cancel
To reset your tablet:
  1. Turn your tablet off
  2. Hold the volume down key
  3. Turn your tablet on
  4. Using the volume down key, highlight Wipe data/factory reset and press the power key to select
  5. Press the volume up key
  6. The reset is now complete.
Note: Resetting your tablet will clear all the data stored, data that's stored on your SIM is safe.
Cheers!!
3answers
How to unlock tablet that has a forgotten pattern on it
if you have a google account, you can do this option
  1. When you try different patterns and unable to unlock your phone in five attempts. Then a message pop-up and shows two buttons "next" and "try again".
  2. Now click on "next" button and you see two options for unlocking phone. One is answer the security question and the second option is to provide Google account details.
  3. Mostly people don't set a security question. But if you set it then simply answer the question and unlock your device quickly. Otherwise check the Google account option and click "next".
  4. Now provide your Google account username and password attached with your device and click on "sign in".
  5. After that you are directed to choose new pattern and now you can unlock with this pattern.
if you don't have your google account, you can do the recovery option, but you will lose all your data in there
  1. Power off your phone.
  2. Now press Volume up, power and home button at the same time and wait until your device starts.
  3. When you see logo screen release the power button and keep pressed the other two buttons.
  4. Now your screen shows android system recovery and there is a list. Use Volume up or down keys to select option from the list. And select factory reset option and then press power button to let the action begin.
  5. Now it asks you for confirmation, select "yes".
  6. After factory reset completes, it again shows you android system recovery screen. Now select reboot option and after restart it will not ask you for pattern.
3answers
How can i unlock the screen on a mid-android 7" tablet that my daughter cannot remember the pattern she locked it with?
After a few attempts to guess pattern it should prompt for the gmail account assigned to the phone. Then allow a pattern reset and confirm.
TOO MANY PATTERN ATTEMPTS ON SAMSUNG GALAXY GT-P7100
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for google a/c details or security question for pattern lock.
tap forgotten pattern and on next screen enter google account details. Then next screen allows you to choose a new screen lock option.
Otherwise for a factory reset use recovery mode
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
1helpful
How To unlock a tablet that too many attempts of pattern made
You can do a hard reset of it and put it back to factory setup like the day you got it.. Usually its pressing the Power button and the Volume Up key at the same time when booting will allow you into the settings.. You can search youtube and there are allot of tutorials that will show you step by step what to do..
Need help unlocking my tablet. I have a message saying too many pattern attempts and I have a new gmail account, but it's not working
I fear a factory reset is your only option. But that's not much of an issue if you use Google backup as everything will be downloaded again when you first log back in to your google account.
My grandson could not get it to come on, so he kept trying to get the right pattern to unlock it, and it froze, now it says refer to google chrome solutions
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Top HKC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a HKC Tablet and eReader Expert? Answer questions, earn points and help others
