Question about Apple iTunes
<!-- from fixya rte -->How do i get into my itunes - Apple iTunes
Itune 306 error
From http://support.apple.com/kb/TS3297
iTunes Store loads partially or returns "Error 306" or "Error 10054"
Proxies, parental control settings and software, security or filtering software, or a bad iTunes Store cache can cause this.
To address proxies, Remove Internet Options proxy settings and connect to the Internet without a proxy.
To reset iTunes Store cache:
  1. In iTunes, choose iTunes > Preferences (Mac) or Edit > Preferences (PC).
  2. Click the Advanced tab.
  3. Click the "Reset cache" button.
  4. Click OK and see if the issue is resolved.
Adjust Parental Controls in iTunes:
  1. Open iTunes.
  2. Access iTunes preferences:
    1. On a Mac: From the iTunes menu, choose Preferences.
    2. On a Windows PC: From the Edit menu, choose Preferences.
  3. Click the Parental Controls tab.
  4. Remove restrictions on Parental Controls.
Oct 22, 2013 | Apple iTunes
Tip
How To Remove Ping's Dropdown Menu in iTunes 10.0.1
If you've just updated to iTunes 10.0.1, you might have noticed the new Ping sidebar and drop down menu. Here are instructions on how to remove them from Mac and Windows.
Mac:
Quit iTunes and open Terminal. Paste the following lines, one at a time, and hit Enter for each:
defaults write com.apple.iTunes hide-ping-dropdown 1
defaults write com.apple.iTunes show-store-link-arrows 1
defaults write com.apple.iTunes disablePingSidebar 1
Windows:
Quit iTunes and open a Command Prompt. Paste the following lines, one at a time, and hit Enter for each:
"%ProgramFiles%/itunes/itunes.exe" /setPrefInt hide-ping-dropdown 1
"%ProgramFiles%/itunes/itunes.exe" /setPrefInt show-store-link-arrows 1
"%ProgramFiles%/itunes/itunes.exe" /setPrefInt disablePingSidebar 1
on Oct 01, 2010 | Apple iTunes
Tip
The ITunesLibrary.itl cannot be read because it was created by a newer version...
1. Quit iTunes.
2. Locate your iTunes folder.
Operating System Default location of iTunes Folder
Microsoft Windows XP and 2000 Documents and Settings[your username]My DocumentsMy Music
Microsoft Windows Vista Users[your username]Music
Microsoft Windows 7 Users[your username]My Music
3. Open your iTunes folder.
4. Drag the iTunes Music Library.xml to the Desktop
5. Drag the following file from your iTunes folder to the Trash:
Microsoft Windows "iTunes Library.itl" (in versions of iTunes prior to 4.9 this was called "iTunes 4 Music Library.itl")
6. Open iTunes.
Important: Do not add any content into iTunes at this point.
7. Choose File > Library > Import Playlist.
8. Navigate to the iTunes Music Library.xml file on the Desktop.
Windows users: Click Open.
on Apr 25, 2010 | Computers & Internet
Invalid response from itunes
After updating OS, you may receive "iTunes could not connect to the iPhone because an invalid response was received from your device".
iTunes Could Not Connect to the iPhone iOS 10 iTunes Invalid Response...
Here are the best four methods for you to refer to fixing this iTunes could not connect to the iPhone invalid response problem, via updating iTunes and iPhone, uninstalling and reinstalling iTunes, and using iPhone alternative.
Nov 25, 2012 | Cell Phones
The file "iTunes Library" cannot
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Nov 09, 2010 | Apple iTunes
Tip
ITunes 9 and the "iTunes Media" folder
Before iTunes 9, there used to be a "iTunes Music" folder that contained all of your music, apps & videos. With the newest version of iTunes, this folder has been changed to "iTunes Media" on new installations. This new folder structure makes much more sense than before, because iTunes is definitely much more than just music now.
However, if you already had iTunes installed before and simply upgraded to the latest version, iTunes will not automatically change the folder structure for you (I guess as to not move an existing user's files around without telling them). You'd have to take a few steps to keep yourself updated.
First, open iTunes, then go to "File > Library > Organize Library". You will be prompted if you want to change to the new iTunes folder structure. However, this will not change your top level folder, "iTunes Music". To do that, leave iTunes running, and simply go to your iTunes Music folder and rename it iTunes Media.
Most of the time this will work fine, because iTunes will detect that there's been a folder change and work accordingly. In case that iTunes didn't catch the folder change, go to "Options > Advanced" and change the location of the iTunes Media library folder manually.
on Feb 23, 2010 | Computers & Internet
Tip
How to re-create iTunes library
Follow these steps:
1. Quit iTunes.
For Microsoft Windows XP and 2000 the iTunes folder is stored in
System drive\Documents and Settings\username\My Documents\My Music\
For Microsoft Windows Vista the iTunes folder is stored in
System drive\Users\username\Music\
Microsoft Windows: 'iTunes Library.itl' (in versions of iTunes prior to 4.9 this was called 'iTunes 4 Music Library.itl')
6. Open iTunes.
7. From the File menu, choose Import.
Note: Do not add any music into iTunes at this point.
9. Click Open.
After re-creating your library, any devices that you sync with iTunes (Apple TV, iPod, etc) will see your iTunes library as a new library and will completely re-sync.
on Jan 06, 2010 | Computers & Internet
ITunes 7.3.2 for Windows 2000
your out of luck. You need to upgrade your pc to xp.
7.3.2 is the newest version of 2000
Well try this
http://www.oldapps.com/itunes.htm
try the
iTunes 7.4.3 (49 MB)
iTunes 7.4.2 (49 MB)
iTunes 7.4.1 (49 MB)
iTunes 7.4 (49 MB)
versions
May 02, 2008 | Apple iPod nano
Apple iTunes Logo
101 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
