When I turn my machine on, after a couple of seconds I get the following error code appears on the screen: "Raise presser foot and needle bar, then turn power switch back on." This message occurs whether the presser foot and needle bar are up or down. Also, when I press the foot pedal, the needle will go down, but not come back up. Please, anyone ever have this problem, and how do I fix it?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Testimonial: "SewTechWayne, can you explain how to adjust a sensor? My husband is a very experienced electrically/mechanically (aircraft and aircraft components expert) so he should be able to adjust or repair as needed."
SOURCE: Janome 9000 willl not work when turned on
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
SOURCE: Janome, memory craft 4800, sewing machine
how to delete programmed patterns and start new lettering
SOURCE: says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
SOURCE: The sewing machine works when switched on, the foot pedalhas no c
there is a clutch operated by foot pedal. if the clutch is continuously engaged then it will run own its own. so adjust clutch lever.
