Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
A
Anonymous Posted on Sep 25, 2014
I moved my sony bravia tv and now it will not work. does not seem to be getting power.
Why does my tv not have power? It is plugged into a working receptacle.
5 Related Answers
Chaz93
  • Posted on Jun 16, 2008
SOURCE: Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
Anonymous
  • 27 Answers
  • Posted on Apr 08, 2009
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Anonymous
  • 197 Answers
  • Posted on Jun 09, 2009
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Dec 31, 2009
SOURCE: My Sony Bravia KDL-40S2000 keeps powering off by
Problem may be the power supply,check in it thoroughly and find the falty components.Remove the faulty one and replace new one.
Such as components may be diod,capacitor,power booster.If you are able to do your self other wise take it to the workshop.
Anonymous
  • 50 Answers
  • Posted on Apr 01, 2010
SOURCE: slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
[email protected]
3answers
Sony bravia 50" red light blinks 6 times.
One thing you can try is to remove all cords attached to the tv including the power cord. wait a few minutes( maybe say a short prayer) then plug the power cord back in and try turning on the tv if it powers up. it maybe a short in one of the units that were plugged into the tv. If it still does not work it maybe a circuit board problem. Sony Bravias have been plagued with a lot of circuit board issues. type in Bravia problems on any search engine and you will see what I mean. You may be able to get it repaired but you best course of action is to buy a different tv. a Vizio or Samsung or anything but a Sony
2helpful
2answers
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
1helpful
I have a Sony Bravia KDS-60A3000. I changed the lamp, plugged in the TV and it was working. Was trying to reset lamp indicator, power went off, red indicator light is blinking and cannot get TV to turn off...
I went to another tech site and saw a suggestion to unplug the TV for a couple hours and then plug back in to see if this helped, but they also indicated this could be a serious power problem. I was really concerned, but tried it and it worked! I think it was running some kind of diagnostics after the new lamp was placed. Back up and running!
161helpful
4answers
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
1helpful
After moving TV cables I can not get AV sign in
It is an imperfect electrical contact.Check the connectors
Moving country with Sony Bravia KDL-46W4100
What is exact model number of your Sony TV to check its specifications that it will work on 230V 50Hz
2answers
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Power problem with Sony Bravia 40 LCD TV
hello my friend, check the power supply first, probably a fuse,but if the fuses are good you have to call the repairman. ps. i have the same tv brand new in the box with the screen broken so if you need any parts let me know
[email protected]
I have a 2 week old Sony Bravia KDL-40V4000 It will not turn on
Try using a different wall plug one you know that works run an extension cord if you have to check it. Lastly are your wall plugs grounded 3 prong plugs? The old fashion plugs with 2 prongs are not sufficiently grounded and that may be your problem and you would need an electrician for that. Otherwise you may have a defective tv. BTW how did you change the fuse in the plug? Are you talking about the breaker box?If so you probably do have a grounding problem.
65helpful
17answers
10000
Good Luck
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
