Hi, me again - further to my previous question, checked y sus board compared to z sus board - z sus "fizzes" (50 Hz) under the big heatsink, but the y sus board is silent. 5V, 60V and 186V supplies are all good. I've fried my devices under that heatsink, I reckon, as there's no other sign of damage.
Whadd'ya think?
SOURCE: SCREEN FOR LG 42PX5D 42 in.
I have dealt with Lg in the past regarding screens and they are unable to sell them as a spare as they are so expensive, they are only used in production and a complete new HD TV is cheaper to buy than a screen. for example LG37LP1D £900.00, a replacement screen £1500.00
SOURCE: Picture gone on an LG 42pc1dv-ec plasma. Sound OK,
Your Vs voltage is high, check if the heatsinks on the Z-sustain board are getting hot after a short time, if so replace the Z-sustain board. If not, dis-connect the Vs & Va plug connection to the Y-sustain & check if the voltages are normal (185V & 80V). If they are then your fault will be in the Y-sustain board. There is a possibility the control board (sits below the power supply) could also be a problem as it is not able to initiate the control to the sustain boards.
SOURCE: Turned my LG 50PX1D tonight and it has a blank
The Y sustain should have a ceramic fuse, possibly 2 and the Z should have one also. Leave the set on for about 20-30 minutes, then shut it off. Feel the large heat sink on each of the boards. If either is cold then that's the culprit. Encompassparts.com has these boards in stock. The Y is 250.00 and the Z is 168.00. A word of warning, the Y can also destroy the Y drive boards also, which are located on the left side next to the Y sustain. Sometimes you can see small pin holes on the driver ic's on the driver board but not always. These boards are non-repairable by us techs and must be replaced when bad. If you have any questions e-mail me at [email protected] I strongly disagree with used parts in any Plasma set.
Testimonial: "yes, i will test after the gym... thanks i will contact you by email."
SOURCE: TV does not boot up LG 50PC1DA
I have LG 50pc1dra i press to turn on green light come on 1sec and the red light gos on nopictur or sound?
SOURCE: LG LCD TV 32LC2D SMPS Problem After much
Here are the service manuals:
http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=32lc2d&kategoria=tv&kat2=all
If the power supply is not made by LG but by other OEM, then it will be hard to fix.
There should be a pin on the board usch as PS_ON or somthing like that, it should have 3.3~5vdc on this pn to turn on the 24vdc and 12vdc section on.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
