When i put on the printer, it keeps showing check fax mode and when trying to print, it shows checks printer mode. any help on this?
SOURCE: canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
SOURCE: My HP deskjet F4810 printer keeps going offline
As described by you , there might be an issue with teh spooler service of your computer , u can follow the undermentioned steps that might help you.
key the commands
net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem)
delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside 32x86, there may be other folders with names starting with "Hewlett-Packard", "hphp" or something else; delete these folders also.
4. In the run (Start Search for Vista) type : c:/windows/system32/spool/printers: delete any files there. By default, this is where the print spooler stores print files.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
(note the space after the = but not before)
2. net start spooler
Cleaning from Registry:
1. Take backup of registry:
2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
The spooler cleaning is complete.
now reinstall the printer .
SOURCE: printer
Top Solution thanks - Take that HP!
Slight amendment as battery is hard to remove:
The battery is accessed by opening top then can be seen on extreme left
at front. No need to take it out, slip a strip of plastic like an old
credit card under the clip on top of battery to insulate it. Then do a soft reset (# and 6 and power
down) with the battery insulated. Power up -
Power down, remove insulator power up. Eureka!
SOURCE: HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
Turn your printer off and turn it back on.
In the Print Queue toolbar you have these buttons:
