Well, that depends.
The real question is: What are you trying to graph?
If you want to graph function y= f(x), then why are you using the Inequalz application, which draws inequations. The ShadeRes(olution) is a system variable needed by the Inequalz application. You can use the default 3 value or change the value to 4, 5, 6, 7, 8.
When Inequalz runs it takes over the graphing functionalities and impose some changes in the calculator configuration, and one of those changes is the appearance of the ShadeRes variable in the Window configuration screen. Also, once the Inequalz App is launched, it remains in memory until you kick it out of Ram, or clear the RAM
My hunch is that you should not be running Inequalz, so I will show you how to unload it of memory so that you can draw your "regular" graphs.
UNLOADING INEQUALZ
- Press the [APPS] key
- The screen INEQUAL RUNNING is displayed with the following selections
- 1:Continue
- 2:Quit Inequal
- 3:About
You press [2:Quit Inequal] to unload the Application from the memory.
Return to your regular graphing and a Window configuration screen without the ShadeRes variable.
TO SUM UP
If you are drawing inequations with Inequalz, you cannot get rid of the ShadeRes variable. You can only give it another acceptable value.
If you are drawing "regular" function graphs, unload Inequalz from memory.
