Control burnt replaced
Good Afternoon friend, thank you for your inquiry!
Based off the information you have provided you replaced the control board and continue to experience troubles with your Frigidaire refrigerator. Normally an "EF" error code stands for evaporator fan circuit failure. This could be an issue with your evaporator fan or main control board. I would suggest consulting with a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this helps to some degree. -Matt
SOURCE: re; control board
behind the display control youll find two slots for inserting a screwdriver and releasing tabs that are holding the control up, no screws just 2 press to release tabs, might be a little awkward to feel might have to twist your head in a little sideways to see them. there is or at least should be a tech sheet mounted to the underneath of the cabinet, just behind the kick plate on rightside
SOURCE: I REPLACED the highout put
Can you please tell me who the Manufacturer is as well as describing the refridgerator as best and detailed as possible? Thank You
