Question about Onkyo Ht-Rc180 7.2-Channel A/V Surround Home Network Receive
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
  • Official Brand Answer
  • 333 Answers
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Posted on Oct 11, 2014
SOURCE:
SOURCE: Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Posted on May 12, 2008
SOURCE: Onkyo HT-R501 7.1 reciever issues
you have to get it fixed. same thing happened to my onkyo reciever and they said it was a bad circuit. had to take it to an onkyo tech and have it replaced.
Posted on Oct 15, 2008
SOURCE: onkyo ht-r500 no speakers attached goes directly
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Posted on Aug 20, 2009
  • 5 Answers
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
SOURCE: I CAN'T GET MY ONKYO HT-R340 AV RECEIVER TO TURN
I have the same problem during years, I have the same av rereiver and the device switchOff (even in standby). The red led is not visible. During several hours, rare time minutes it is blocked.
I sent it, the last year to the official technical service and they said me that nothing matter with it!!!
The worst buy made by me, goodluck, if you have solution I will be pleasure of your information
Juan Luis Santiago
Posted on Feb 05, 2011
How to reset onkyo HT-R395
Hi, please see procedure below.
Resetting the main unit Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this. 1 Switch the receiver into standby. 2 While holding down STEREO, press and hold ?ON/STANDBY for about two seconds. 3 When you see RESET? appear in the display, press SURROUND. OK? shows in the display. 4 Press DSP to confirm. OK appears in the display to indicate that the receiver has been reset to the factory default settings. Important • If the Standby Through is not set to OFF, you may not be able to initialize the unit.
Dec 31, 2016 | Onkyo Audio Players & Recorders
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
HT-RC180 all of a sudden no sound output (not muted, etc.) Turned it on yesterday, and everything works, but no output. Observations: No static/noise floor when volume is increased to maximum-absolutely...
Hello, I think that I may have responded to you via an email sent to our customer support. If you are not the person that I responded to please email me at askonkyo@us.onkyo.com with your serial number. Thank you, Onkyo USA
Jun 30, 2017 | Onkyo HTRC180
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
it on and, while holding down the [VIDEO 1] button,
press the [STANDBY/ON] button. “Clear” will
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Apr 24, 2010 | Onkyo TX-SR606 Receiver
Have ajustments all screwed up
If you can’t resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. “Clear”
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Feb 10, 2010 | Onkyo HT-S9100THX 7.1 Channel Receiver and...
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
Jul 14, 2009 | Onkyo HTR500 Receiver
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Onkyo Ht-Rc180 7.2-Channel A/V Surround Home Network Receive Logo
393 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
