HP PHOTOSMART PLUS B209A All-In-One Printer Logo
A
Anonymous Posted on Sep 24, 2014
How to clean and align HP B209a printer
Suddenly doesn't print. Almost new ink cartridges.
Marlene Olsen
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 25, 2014
Marlene Olsen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11700
Points
Every time I had this problem it was the printer head. Try removing the cartridges, then the printer head. Be sure the head is seated firmly. Try printing again. The printer head expires long before it's suppose to so don't be surprised if this is the problem.
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on May 14, 2007
SOURCE: HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
sagarjd
JD Kiran Sagar
  • 95 Answers
  • Posted on Nov 21, 2008
SOURCE: Printer won't print properly.
Please perform the following steps:
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Regards,
Sagarjd
Anonymous
  • 849 Answers
  • Posted on Nov 29, 2008
SOURCE: Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Anonymous
  • 8 Answers
  • Posted on Mar 14, 2009
SOURCE: 4315 Hp Printer will not align.
restart your printer like this: go to control panel>
performance and maintenance>administrative tools> services> scroll down until you come to print spooler, click on this then on the upper side of your screen you will see restart, click on it.
This should get you up and running. Shame on your repair man for not showing you how to fix the problem.
You could even try not aligning the cartridges, this will just cause your printer to spit out an alignment page each time you turn it on but still should go ahead and print for you.
let me know how if this helps.
[email protected]
Anonymous
  • 19 Answers
  • Posted on Aug 24, 2009
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
2answers
I am printing an invitation on my HP Officejet 7210 All in One. I am gettting striping in areas which have a lot of solid black. How can I fix this?
From the HP Toolbox on your PC you can run a cleaning page. If that doesn't fix it, or if you are using refilled ink cartridges, it may be time for a new black ink cartridge.
Hello, my HP Photosmart All in One 209b printer will not print black ink; the output is a light gray. Also, I cannot get the diagnostics page to print out. The alignment page only prints the top color...
First try removing the printhead and cleaning it manually by soaking in a cleaning solution(50% windex or similar and 50% hot water). ALso the ink cartridges amy be dry even if the ink level shows normal level. Get a set on ebay for a very low cost and clean the printhead and you should not have a problem with printing at all.
Link to one of ebay listings: for USA:
https://www.ebay.com/itm/382706888626
For UK:
https://www.ebay.co.uk/itm/262487581895
My HP Model B209a Photosmart Plus all in one printer has quit printing black ink. New cartridge installed but still no black ink is printing.
on the head assembly, you will see some copper pins contacts, try to clean them with cotton swabs dab in alcohol..same with the print cartridge contacts..
My hp officejet 7410 printer which has been working fine for a year suddenly will not print. after putting in new cartridges it printed out an alignment page. But still will not print a normal page. ...
Click on the Setup button,
Scroll till you find Tools - Press OK
Scroll till you find Clean Cartridge - Press OK
It will print an alignment sheet. Align the printer
If this does not work - try the Align Printer Option from Tools of Setup menu again from Printer front panel.
Let me know if none of these work.
Regards,
Shawn
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
[email protected]
Once we ran out of ink and replaced it the printer would no longer print
Remove the cartridges and clean the copper contacts of cartridges with lightly moistened lint free cloth. Do not insert them in printer after cleaning
Power cycle the printer by following steps when cartridges are out
1- unplug the power cord from back of printer when printer is tuned on
2- Wait for 30 seconds
3- plug the power cord and turn on the printer
Insert cartridges, it should start aligning automatically
It will print an alignment page, place the alignment page on scanner glass and press ok
Suddenly won't print; had sat idle for few days;
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts,
My printer stopped printing
your senser is off you have to tak it in for minor repairs
k24674
Grand Canyon Tech
Grand Canyon Tech
