Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Define hunting.Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Define hunting.
You can't post conmments that contain an email address.
Question edited for clarity. 'Karcher not 'Kracher', add (what it is).
Question moved from Washing Machines category.
It sounds like the contactor has failed internally. This often happens that the internal contacts arc and burn away. The click is the electromagnet still working. Take it off and test it, or leave it on and test the output for continuity once energized.
Not sure what the 'o.eltro' means? There is help in the link and the service manual for a different series of HDS washers. You could also contact Karcher direct.
www.manualslib.com > ... > 325 MAGNUM 4X4 HDS A00CD32FA View and Download Polaris 325 MAGNUM 4X4 HDS A00CD32FA parts manual online.Polaris Automobile Accessories Parts Manual. 325 MAGNUM 4X4 HDS ...
It could be one of two things, first have you bleed the pressure off the unit then tried to restart it. or it may be the pump is locked up and will not turn.
First use "add gps" and add the original unit and the H20
use "receive from gps" to call in the original waypoint file from your sd card
use "send to gps" to save the new waypoint file to the sd card
remember that the original gps file may contain more waypoints than the H20 can hold so you may have to delete some waypoints from the file while in EasyGPS
if this is not clear enough, let me know and I will try again. I use the program all the time. I just realized I left something out. EASYgps does not like the Lowrance HDS File version so an extra step is required if you are transferring files from an HDS to an IFinder. Save your HDS waypoints as Version 3 to the SD card and EASYgps will accept them
Test your Lowrance HDS 7 on different power sources e.g. on another motorboat to find out whether this is the problem of the boat's power supply or the HDS 7 itself - this advice will only help you to determine whether to call the boat-repairman or the lowrance hds 7 seller warranty service.
Dear dumbelldaveb,
Having a 13A fuse I am concluding that the machine is single phase. Most probably you have a faulty capacitor. Check the capacitor and if you find it expanded and leaking...then you must change it with a new one. If you see the capacitor is normal just the same it could be shorted. So change the capacitor with a new one and try to start the machine WITHOUT LOAD. Which means no water inlet and no gun attached. Doing this you can also remove temporarly the micro switches. If the motor still hums, then most probably there is a fault in the electric motor.
Now if you find out that the fault is the capacitor (which in my opinion it is the case)...you must see why the capacitor broke. If when using the machine and the gun is closed, the machine starts on and off on its own,...this will damage the capacitor. This on and off fault could come from a leaking gun. Or a leak from the seals. Whatever....the machine must not be left going ON and Off when the gun is closed. This ON and OFF could be due to faulty micro switches and control valves.
I am very sorry to mention a lot of things, but I hope as in many cases,..the changing of the capacitor will solve the problem. I wish to add that the electrical lead wire must be checked. On many occasions I found that the electrical lead wire from the plug to the machine was damaged and shorted, ..due to pulling, wear and tear.
Regards,
Fulltech.
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
