Linksys Wireless-G WRT54G Router Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I secure my connection with a Belkin N wireless Model F5D8233-4? When you go to wireless connection it is not secured like others I see. Can't figure out how to do it.
Anonymous
Level 2:
Sniper:
  • Expert 53 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
53
Questions
Helped
35121
Points
209
You can follow page 45 and on for this of the user manual:
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
Anonymous
Level 3:
  • Linksys Master 6,487 Answers
Anonymous
Linksys Master
Level 3:
Answers
6487
Questions
6
Helped
1557165
Points
18452
You can access this link and follow the steps there on how to enable wireless security on your network
http://www.belkin.com/support/article/?lid=en&pid=F5D8233-4&aid=10177&scid=221
I have a Belkin N wireless router. It's all set up but it shows as not being secured. How do I secure it? Model F5D8233-4v3
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
I want to take the security lock off my belkin f6d4230
Hi here is the answer for your question:
1. We need to establish a direct connection bit-win your router and your pc or laptop using the UTP cable one side of the cable must need to connected to one of the port in the back side of your router the other side to your lan port.
2. open explorer or any browser you using and type on the top search bar 192.168.2.1 this is the address of your router press enter and you will contact your router set up page.
3. after you must go to wireless security that appera in the left side of the page, after that you will able to change the password of your wireless security.
more question let me know
Techbelkin
I have a belkin F5D8233-4V3. I never had it secured before. Then I made my old pc wireless and it hooked up to my b elkin and it works fine. Trouble is now it appears to be secured and I cant access it...
The security settings ie. encryption is configured in the Belkin wireless settings. You then configured your old wireless card in you computer with these settings so it can connect to the Belkin.
I suggest you also apply these same settings to the wireless cards in your laptops.
To make your wireless network secure from unauthorized access, please click on this link and follow my instructions :-
7helpful
How do I find out the security key for belkin router?
if you want to remove security key, just reset the router by pressing the hole or reset button and then type in brower 192.168.1.1 and access in your router.then you can assign new security if you want or leave without security. just connect your computer by hard wire and by same wire other end of this wire will connect to router. don't need to do anythig. computer n router knows best everything else what to do.
I want to make my broadband secured.
The model that you have listed is not a wireless router, so if it isn't, the only way people could be connecting is if they are physically connected to your router. If you do have a wireless router, please list the correct the model number.
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Cannot mae my belkin wireless router secure
type in http://192.168.2.1 in start>run>
you will get the interface which say Router set up page
>click on security under wireless extream left
>if you have password enter click submit (if not) live password blank click submit
>select the security type
>creat the password
>apply changes
>cloce the belkin page
> and connect the wireless computer to the secured network
Belkin Modem Router not connecting to desktop
The wireless security on your router might be enabled.
1. In the address bar of your Internet browser, type "192.168.2.1". Then press the "Enter" key.
2. It will prompt for a password to access the Router’s Web-Based Advanced User Interface. By default the password is blank.
3. Go to Security, then Wireless.
- Check the wireless security settings, this should match the settings on your wireless computer.
4. On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Unable to use other wireless devices with belkin f5d7630 router
Make sure that the wireless devices which you want to connect has the faciltity of accepting the security passwords of the router
2answers
Connecting to secure network
when enabling wireless security the router and adapter must be both be configured and configured in a fashion that both support. If you need help provide confirmation of your wireless router's manufacturer and model and the same information for any wireless adapters or computers with built-in wireless adapters to be wirelessly connected.
This will allow us to determine the common security options for all wireless devices you have.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
