SOURCE: craftsman garage door opener
you can order a new gear kit from amazon for $20. It's and easy fix.
SOURCE: motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
SOURCE: Clicking sound - door doesn't open or close
Turn off the breaker for the unit. Set up a good ladder, change the bulb. Release the opener from the door,turn the breaker on, and try the opener while it is disconnected from the door. If it works, give the chain a good spray of wd40, followed by a good spray of chain lube or spray grease. Operate the motor back and forth, spray grease wherever the chain attachment rides the bar. Once it is working good and free, try to connect it to the door and test it. If it has a problem, check your door rollers and hardware.
SOURCE: Craftsman 41AC1502M Garage door opener: We are
There is a very good possibility you have a bad logic board. If you had more than one car remote and they both acted the same it would be definite.
SOURCE: My garage door hums but does not open. It had
Sounds like you have a bad start capacitor. It sits next to the motor and is about the diameter of a silver dollar and about 5 inches long. You can get one at any good door opener service company.
