The heat from the light bulb dried out the plastic hose on the dispenser. the tubing is 1/4 in and I used a brass compression fitting brass insert . I cut off the head of the insert so the tube was round and could be used to join a short piece of plastic tubing to the existing plastic tube in the door. Cut off the damaged section of tubing in the door and replace that length with new plastic tube. Push the brass insert halfway into the new plastic tube and then into the existing tube in the door. Route the tube into the original metal part on the door and it's done.
