It has the 33/45 flip to 78 cartridge stylus on it. Even if I could only play 33 it would be great to get it going again.
Every cartridge has a maker and model number. You find them and enter it in google and it should come up with both.
However you don't have to have the same make of cartridge. You just need to find one that fits. You do need to bear in mind however that some of the cartridges that use 78 rpm stylus sometimes are Ceramic cartridges. This means that they don't need a pre-amp for it to be the same level as say a tape deck. Many cartridges these days are Magnetic. This means that if your amp doesn't have a pre-amp for these built in, then getting one of these cartridges will mean a purchase of a magnetic cartridge pre-amp. Some of these magnetic types of cartridge have no ability to fit a 78 stylus. In others you can get a 78 stylus available separately.
For example the Stanton 500 has this ability. One I use too!
The reason you might want to get a magnetic cartridge is that they give better sound quality over the ceramic type - well on 33 and 45 anyway!
SOURCE: "Remove and Check Color Cartridge" won't go away w/ new cartridge
Replaced with brand new HP cartridges. If either one (black or color) is a refilled cartridge, my machine has issues.
SOURCE: I have an epson RX595
you are told to replace your cartridge why because the printer software detects it might be out of ink that it is commonly happened
SOURCE: A couple days after replacing
Hello ,you have change the cleaner also or not,if not then replace the cleaner & clean the entire unit by a blower.Also clean the encoder strip with a smoth cloth,clean the print head flex ckt with clean cloth,altough problem persists then replace the ink tube *** & encoder strip.
SOURCE: epson stylus photo rx700 lockout
Look for cartridge sensor and clean them with a piece of close. re-install the cartridge and see if the problem is solved. if not may be U have bad sensor so replace with new ones.
