Question about Sigma Bc 906 Computer
Need help reseting for tire size 26x2.1 changed to road tires can't find my book it's a sigma bc 906
    Problem Solver:
  • 5 Answers
You can measure your wheel by placing your bike on a flat surface with the valve stem on the wheel in the bottom most position or 6 o clock position. mark the floor where the valve stem is. now roll the bike forward so that the wheels gets one full revolution and the valve stem comes back to the 6 o clock position and mark the floor at the valve stem. now get a tape measure and measure the distance between your two marks. Convert this measurement to usually centimeters. that will be the number that put into your computer.
the manual can be downloaded here
Rick
Bicycle Parts and Accessories
Posted on Jul 10, 2009
SOURCE:
Can the spoke magnet go on the rear wheel sigma bc 906
You should be able to use it on your indoor trainer. The Sigma will need a wheel diameter callbration to give correct readings.
Jan 29, 2013 | Sigma Bc 906 Computer
What is result of tire size setting of 2.224 versus 2.233
The calculated size is more accurate, whereas the manual suggests a setting. If you cannot set the size accurately then use the suggested setting.
Apr 22, 2012 | Sigma Bc 906 Computer
How can you turn the Sigma BC 906 off?
I can not off Sigma 906. It is working but can not be closed. Please help
Nov 25, 2010 | Sigma Bc 906 Computer
I need to program a sigma 906 for my recumbent with a 20 1/8 wheel size. Is 1254 the right entry in wheel size?
The number you are entering should be the circumference of the tire, measured in millimeters. 1254 looks pretty small for your wheel. You can get the circumference by rolling the tire one revolution and measuring the distance with a tape measure. I usually lay out the tape, start with the tire valve at zero, roll one revolution, and read the number. Of course this number could be off by a few percent as the tire isn't exactly the same size due to rider weight, air pressure, tire wear, and temperature. If the error is large you need to do some riding on a known distance, like a running track, and then tweak the number up or down slightly until you are happy.
Apr 20, 2010 | Sigma Bc 906 Computer
I need to reset my Sigma BC 1200 bike odometer. What is the 4 digit number for my tire size of 700x35C = 28x1 5/8 JOe Joep@cascadecolumbia.com
I had the same problem...the online code that sigma gave is way off. I had a 700x23c and it was telling me 2133. Sheldon's site told me 1302 which seems much closer. I'm heading out tonight to test it. Here's the site... http://www.sheldonbrown.com/cyclecomputer-calibration.html#ccc
Mar 30, 2010 | Sigma Cycling
Sigma Bc 906 Computer Logo
1,079 people viewed this question
Top Sigma Cycling Experts
JohnLong
Vincent G
Vincent G
Are you a Sigma Cycling Expert? Answer questions, earn points and help others
