When you are sure you have a good battery and the voltage regulator works fine, I should think there is something eating power during the time you switched off. Years and years ago sometime a car radio was connected wrong and would not switch off when the contact was off. Now you should disconnect the battery when you switched of and use a huge ampere meter DC to see if and if so what current is "leaking" away If there is no current, then check the barrery and the voltage regulator.
