If it's not the thermocouple, then the control valve might have failed. There isn't much else that can cause this.
Is this something I can fix myself, or is it going to be pricey?
The control valve and burner are usually assembled as a unit. Given the need to disconnect and reconnect the gas supply, it would be safer to let a pro do this. Depending on the age of the unit, it might be covered by warranty. Consider the condition and age of the tank, as well as repair vs. replacement cost.
The thermostat / unit control valve is probably a $60 to $100 part.
SOURCE: AO Smith water heater about 4 years old pilot went
It sounds like your flame detector (usually a thermocouple) has gotten weak and when you cleaned the pilot the stronger flame was able to generate enough power to keep the gas valve working. If you replace the thermocouple your problem should go away. If a new thermocouple will not keep the gas valve operating...the coil in the gas valve has gone bad and you will need to replace the gas valve assembly. (most valves do not have replaceable coils).
SOURCE: Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
SOURCE: GE gas water heater lights for only a few seconds.
Called GE and there is a glass vile under the burner that is defective and cuts off the oxygen.
They are mailing out a replacement to my house & have contracted a plumber to install. waiting 4 days now. They say that the glass vile incinerates and there is not any thing left to it. The burner area is full of black soot. will post again one fixed.
Testimonial: "This is an accurate description of my own follow up. That device, a TRD, was the indeed the problem. "
