Sounds like fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time
SOURCE: IR reciever in my Magnavox 15MF400T/37 does not respond to the remote.
You basically have to take the tv apart backward to get to the front. Start with the back panel unscrew all the screws. Then you will see the internals. IR sensor should be botton left side if you looking down on it.
SOURCE: Apex Digital TV Model: 1919. Worked fine for a
Power supply issues or shorted horizontal output transistor. Probably not worth having repaired unless you DIY....
SOURCE: The TV stopped receiving IR signals from remotes
make sure that your remote has a line of sight to the tv. often a small antenna is added to enhance reception. also check to be sure your remote batteries are aok.
SOURCE: Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
SOURCE: Samsung LN46A550 TV with a Xentech IR receiver 291 Series
Just got a new Samsung Flat screen today and am new technology challenged. Cannot sleep because the red light is still on on the tv set, read the instructions, and would this red light mean that it is in standby mode? Do I unplug the tv from the wall? I am getting very sleepy.
